Old August 10th, 2017, 17:40   #181
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
Originally Posted by jimbote View Post
yeah, i'm captain obvious... i studied the diagram and posted a response before i read moto's reply
Nah man, you got it right.. Shouldn't be any need for + or - (aside from having them hooked up) or a Dakota digital unit. The data is traveling down the third line... + and - just power the sensor.
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old August 10th, 2017, 18:19   #182
Motohead1
Yea the white/orange puts out a non-square voltage that the VW VSS dosent like and it pegs my speedo with just a key on.
Motohead1 is offline   Reply With Quote
Old August 10th, 2017, 18:59   #183
jimbote
jimbote's Avatar
what speedo are you using ?
Old August 10th, 2017, 19:13   #184
Motohead1
Ok I havent given up on this yet. The fact that Reddoks setup works has me thinking something is missing from mine especially since I just confirmed the dakota puts out a 8000ppm signal. If thats true it lines up with what the VW VSS wants to see.
see here http://www.rostra.com/support/vss-search.php
Can the brake switch signals be messed up? Can that cause the ECU to not read the VSS signal?
Anyone want to put there ride up on jack stands in gear engage the brake switch just enough to see if the VSS signal cuts out?
Old August 10th, 2017, 19:14   #185
Motohead1
Stock dodge gauges
Old August 10th, 2017, 19:17   #186
jimbote
jimbote's Avatar
Stock dodge gauges
so why is the stock vss signal making the stock speedo go wack ?
Old August 10th, 2017, 19:21   #187
Motohead1
Thats what I want to know. Maby pin 20/121 is messed up inside my ECU? Maby the dodge is seeing a ground. I will put a diode inline and see if that helps.
Old August 10th, 2017, 22:36   #188
jimbote
jimbote's Avatar
does the stock dodge speedo usually get it's signal from a vss or via can ? pin 20 on the ecm is only for vss input ... your speedo will have to get it's signal elsewhere... try the white/orange directly to pin 20 to see if speed registers in vcds and forget about the speedo for now
Old August 11th, 2017, 06:29   #189
timmyc4
timmyc4's Avatar
Fuel Economy: 51.3 Best @ 65mph/300mi trip
Smile Health - Live life
I used to be into doing all this B.S.
I got Terminal Cancer, am almost beating it and have LEARNED that this is a WASTE of time!
Life is short when you realize that this is all junk and the time you stick into it.
Buy yourself a nice 4x4 Manual Diesel Ford or Dodge or Chev for that matter with low miles or rebuilt. Nope you won't get the fuel economy, but on the other hand, you'll have reliability, durability and a GREAT puller, which you won't get with a pip squeak TDI in a vehicle it was NEVER desined for. I've had many TDI's... GREAT for what they were DESIGNED FOR! Buy something off the shelf so you can work on it or something some FOOL aready wasted his time doing!
Forget about this CUSTOM waste of time headaches and go have fun with your family. Spend your time fishing, playing with them. This is a waste of your valuable life.
You only have a limited time here, don't waste it on chasing the wind.
timmyc4 is offline   Reply With Quote
Old August 11th, 2017, 08:24   #190
\/\/0J0
\/\/0J0's Avatar
The Dodge (and Jeep) stuff feeds the cluster via the CAN bus so the vss should output to the PCM which will then drive the cluster.
I miss my TDi
Old August 11th, 2017, 10:07   #191
Reddok
Reddok's Avatar
Fuel Economy: Jetta: 40.8 avg, 47.1 best. Jeep: 30 avg.
I believe there are two switches for the brake light and you need both of them connected for the cruise to work. Can't really remember - it's been so long now. Not sure that it would kill the VSS input though.
2000 Jetta 01M: Ventectomy, Snowscreen removed, Injection timing advanced, EGR dialed back.
2002 Jeep Liberty TDI Project: 2002 ALH, 1749VA, NSG-370 6-spd, PP764's on T4's, 11mm pump, PD150 intake, custom tune, Cummins lift pump, 2.8 CRD intercooler, 2.5" DP/exhaust with Magnaflow cat and Walker Quietflow muffler.
Reddok is offline   Reply With Quote
Old August 11th, 2017, 10:27   #192
Reddok
Reddok's Avatar
Just re-read my own swap "The cruise control also works. With no cluster. The Jeep BCM puts out a conditioned 5v square wave to the ECU for cruise speed. The Jetta cluster puts out this same signal. So connecting the Jeep BCM to the Jetta ECU got me a valid speed reading. "
So I did not use the signal from the diff speed sensor, I must have found an output from the Jeeps body control module (near the fuse block) that had the proper signal.
Old August 11th, 2017, 11:24   #193
john.jackson9213
TDI(s): 1996 B4V
Lot's of wisdom in the above. My better half keeps telling me just go buy a new car and have fun. But I tell her I do like puttering with this car crap. The kids are very much into their own stuff. Still, a whole lot of wisdom in the above post.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old August 11th, 2017, 11:31   #194
jimbote
jimbote's Avatar
it doesn't interrupt the vss signal
Old August 11th, 2017, 13:53   #195
h4vok
h4vok's Avatar
Fuel Economy: 35 to 50
Some people enjoy wrenching and building something they can be proud of. You have a right to your opinion, but realize where you are posting this.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
2000 dodge dakota quad cab 4x4 with tdi jetmoto3 Private TDI Items for Sale/Wanted 6 October 26th, 2015 11:36
FS: Dodge Dakota 2.5L Bellhousing Kriesel Private TDI Items for Sale/Wanted 1 April 12th, 2010 10:05
WTT: My 99 Dodge Dakota for a TDI. Smola67 TDI Cars for Sale/Wanted 1 June 13th, 2007 02:25
1999 Dodge Ram 3500 Quad Cab SLT, Cummins Diesel Dieselworld TDI Cars for Sale/Wanted 2 March 23rd, 2005 19:31
1998 Dodge Ram 2500 24v Cummins Turbo Diesel Quad Dieselworld TDI Cars for Sale/Wanted 10 March 7th, 2005 10:22
Page generated in 0.19802 seconds with 11 queries
[Output: 137.81 Kb. compressed to 116.20 Kb. by saving 21.61 Kb. (15.68%)]
