Old July 20th, 2014, 18:56   #1
nubz69
Fuel Economy: 40ish
Default 2000 mk4 Jetta - All keys are lost, Now what?
I have a 2000 mk4 Jetta and have just lost the last key to the car. I never had a fob with it, only valet keys, but that wasn't a big deal until now. I ordered a new key from the dealership but they are telling me that I have to get the car to them to program the key. That means that I am going to have to pay for a very expensive tow, just to get there, before they can program it. Is there a way to program the key myself with a vcds? I have seen that you can program fobs but I have not seen any info on just a single key.
nubz69 is offline   Reply With Quote
Old July 20th, 2014, 19:50   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Check this out: http://sidewinderkeys.com Mark knows VW keys.
-George Bernard Shaw
Old July 21st, 2014, 06:24   #3
jessabug
jessabug's Avatar
x2 on sidewinder keys. They cut keys based on VIN so you'll be able to get into the car. Then you'll need someone with VAG-COM and VAG-Tacho so you can get the key code and program the key to the immobilizer. VAG-COM can program the fob (if you get one). No need to go to the dealer.
Hers: 2003 20thAE GTI, 3" 42DD turbo back, Unitronic Stage 2, 139k
His: 2001 Jetta TDI GL, auto->manual swapped, 165k
The old skool project: 1984 Jetta TD GL, 190k, 2.5" exhaust, Giles IP
jessabug is offline   Reply With Quote
Old July 21st, 2014, 06:37   #4
Genesis
Fuel Economy: 53/48/42
You need the SKC code out of the immobilizer; either you have it or you need someone who has the program to pull it.
Once you have it VCDS can program keys using it; using the VIN you can get a key that will turn the ignition and unlock the doors -- the remaining piece is the SKC to program it.
The dealer can no longer (for the last 10 years or so) pull SKCs and give them to you -- it's all done online now, so they're not lying when they say they can't give it to you. Most cars of that vintage came with it in the owner's package, but that's probably long gone.
I pulled mine out of my '03 cluster a long time ago and have it, so if I ever need it.... you need to find someone with the software that can extract it, in short.
Genesis is offline   Reply With Quote
Old July 21st, 2014, 10:49   #5
AARodriguez Corp.
AARodriguez Corp.'s Avatar
Sidewinder does not cut key keys by VIN.
AARodriguez Corp. is offline   Reply With Quote
Old July 21st, 2014, 11:08   #6
jessabug
jessabug's Avatar
Well we sent them our VIN and they cut us a key...
Old July 21st, 2014, 16:10   #7
1854sailor
Resident Curmudgeon
1854sailor's Avatar
According to their website, they can indeed!
Old July 21st, 2014, 16:39   #8
AARodriguez Corp.
Cool, I stand corrected!
Old July 22nd, 2014, 04:48   #9
nubz69
Fuel Economy: 40ish
Thanks for all the help guys. It sounds like I am just going to have to for the cash over to the dealership and have the car towed there. I dont own a vag-com or vag-tacho and there are not gurus close enough to my area anymore. I can't believe how expensive of an accident this has become.
Old July 24th, 2014, 07:22   #10
PakProtector
ummm...get more than a single replacement.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is online now   Reply With Quote
Old July 24th, 2014, 08:42   #11
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
I'm wondering if your dealer visit cost might be equall to a tune with an immo delete with new cut keys. Something to consider...
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old July 26th, 2014, 18:40   #12
nubz69
Fuel Economy: 40ish
I have thought about that but I am not sure I can convince the wife that instead of getting the key working, I need a whole new tune.
Old July 27th, 2014, 06:25   #13
scooperhsd
+1 on getting more than 1 key. The valet key will run about $90 each (plus programming at the dealer - for 2 keys you're looking at $230-$250 for keys and programming). The Flip keys that will also open the trunk / glovebox are about $150 for both parts together.
When I got my NB, it only came with 1 flip key - the FIRST thing we bought was a valet key (which I use and keep on my vehicle ring with my motorcycle key).
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old July 27th, 2014, 22:04   #14
TDI in MT
TDI in MT's Avatar
Here's another option: You can buy uncut flip keys with electronix in them from fixmyvw.com for $40. This is what I did, and took it to a local locksmith who actually cut the key for another $40. They were able to dial into VW's system and, based on the VIN number, cut the correct key. But they couldn't program it to the car.
Because I did have a working key before all this started (it was my only one), I drove the car and the new keys to the dealer 100 miles away so they could reprogram everything. They billed me $50, well worth it to me.
TDI in MT is offline   Reply With Quote
Old May 23rd, 2020, 01:09   #15
fatmobile
I know this is an old post.
Went to fixmyvw.com and it's now called:
https://www.tunemyeuro.com/
This is for a 2000 Jetta.
Do I want the immo 2 compliant fob?
or the immo2 fob?
https://www.tunemyeuro.com/1998-2001/
It does say:
"This key is cut by picture only, we will not cut these keys by VIN number."
fatmobile is offline   Reply With Quote
Lost both keys.......what now? blu_jet_92 VW MKIV-A4 TDIs (VE and PD) 33 November 4th, 2011 22:13
Lost Keys LukeWilson TDI 101 4 December 20th, 2010 01:17
LOST KEYS Help :( tj421rb TDI 101 12 January 30th, 2008 15:23
LOST KEYS!! 98 Jetta TDI PWN General VW Discussion 1 August 15th, 2002 08:07
Lost both of my keys. P180 General VW Discussion 11 January 4th, 2002 18:11
Page generated in 0.88980 seconds with 11 queries
[Output: 125.44 Kb. compressed to 104.28 Kb. by saving 21.17 Kb. (16.87%)]
