Old November 30th, 2005, 16:27   #1
clay1260
Default Car wouldn't start...
OK so I was at the "fillin station" and just topped off my '03 NB all the way up the neck via venting. Get back in the car and turn it over and the car "fires" or "combusts" for about half a second then goes back to cranking. It would continue turning the car over as long as I held the key to "start". Stop, reset and try it again....same thing for about 10-12 times over a five minute time frame. Finally it hits and cranks as normal. What is the deal? Strange. Got home and it seems to be fine now.
clay1260 is offline   Reply With Quote
Old November 30th, 2005, 16:47   #2
Dana Hanchett
TDI(s): 2011
Smile
Probably lack of air. Common problem and easy to fix. Check your "change-over" valve aka. anti-shudder valve. Its right next to the EGR valve. Push on the side linkage to close the valve and see if it sticks closed. If it does wipe out the goop (mixture of soot and oil) with clean rags after you take off the spring hose clamp and pull the hose off. Using a heavy load of fuel treatment will help in preventing (not eliminating) this problem.
Dana Hanchett is offline   Reply With Quote
Old November 30th, 2005, 17:20   #3
clay1260
thanks Dana....I may have had the inlet hose off to this device a couple of weeks ago when I was having alternator issues. I wiped the area clean as much as possible and it was full of gunk. But I will definitely look at that, thanks again.
Page generated in 0.10806 seconds with 10 queries
[Output: 52.65 Kb. compressed to 47.61 Kb. by saving 5.04 Kb. (9.57%)]
