Old December 6th, 2018, 08:07   #1
andyhol
TDI(s): 98 Jetta
Default missing crank pulleys, replacements anyone?
98 jetta, mk3, vbelt drives 2 pulleys, probably power steering and water.
The two crank pulleys are gone leaving two sheared bolts.
Anyone have or know where I can get replacements. I have found the serpentine pulley on ebay, can't find the vbelt pulley.
part #s ?
Any help would be great, the car is currently off at college with my son and trying to get it home for xmas break
Thank you
Andy
andyhol is offline   Reply With Quote
Old December 6th, 2018, 22:34   #2
Steve Addy
TDI(s): 97 Mk3
The two crankshaft pulleys are the serpentine, which is actually a harmonic balancer and a v-belt pulley, which drives the WP and the PS pumps.
Am I to understand that the bolts sheared off and both of the crankshaft pulleys have gone missing?
The balancer is quite common to find since those fail, but the v-belt pulley is less common because those don't fail.
The harmonic balancer is part # 028105243T
The v-belt pulley is part # 028105253A
Hope you're able to get the vehicle home!
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old December 7th, 2018, 04:37   #3
andyhol
TDI(s): 98 Jetta
I would suspect two bolts came out and the last two broke.
Yes the pulleys 2went away and my daughter was driving at the time.
Thank you for the numbers
Andy
02 Jetta tdi. Missing ,,some black smoke ,,weak when missing umpflash TDI 101 4 April 28th, 2014 10:09
Crank pulley bolts have gone missing :/ Silentmunky VW MKIV-A4 TDIs (VE and PD) 8 February 7th, 2012 12:55
asz block complete with pistons crank and pulleys tebotsc Private TDI Items for Sale/Wanted 1 February 7th, 2010 13:15
New Pulleys heinicke9858 TDI 101 4 December 27th, 2005 17:30
Underdrive Pulleys? globug TDI Power Enhancements 2 October 3rd, 2002 18:10
Page generated in 0.15545 seconds with 13 queries
[Output: 57.48 Kb. compressed to 52.29 Kb. by saving 5.19 Kb. (9.03%)]
