wonderwilley
Ok so after my last timing belt job a month or two ago, I swapped both engine mounts and also the dog bone. I thought I had them All lined up right but when it was all back together I was having quite a bit of vibration from the engine. I’ve since tried to adjust the mounts and I seem to be making things worse. I think I’m pretty far out of spec now.
I’ve been supporting the engine with a floor jack and prying and pulling to get things lined up. Clearly this isn’t working, I think I’m kinda fighting the wheels on the floor jack. Would one of these be a better way to go?
https://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Is there a good way to start over idk. Would I be better off pulling the dog bone off to get the side mounts lined up? I’m just fighting way too hard to set the engine in place before I tighten things up. I’m seriously loosing my mind here, been working on cars my whole life, 2 successful ALH timing belts under my belt and a ton more. Why is it go effing difficult for me to set a couple engine mounts idk. Any help would be great, thanks in advance.
