My glow plug indicator light is flashing. Scan for codes and this comes up
16955/P0571/001393 - Brake Light Switch (F): Implausible Signal
Called the dealership about the brake switch recall and he said that it was already fixed on my vehicle. So I put two new brake switches in from the parts store. I verified operation with my multimeter and both are working correctly.
All 3 brake lights work. All the running lights work.
The cruise control light comes on when I flip the switch, but it won't activate and hold my speed for me.
When I measure block 6, the brake signal block measures 110 or 111 depending on if the brake is depressed. The cruise control blocks change according to each button press and brake press.
When I clear the codes with the car off, it goes away for about 5 min, then comes back. If I try and clear the code with the engine running then it just stays there and doesn't clear.
What else could be the culprit of this code?
