romad
The rubber segmented gasket around the shifter column has deteriorated into pieces. These pieces are causing 2 problems:
First, it is harder to shift into Drive
Second, the gear indications on the shifter no longer illuminate the correct gear, i.e. when I shift into reverse, the "N" is lit and when in drive the "4" is lit.
Can this be repaired without replacing the whole transmission? Ideally, I'd like to have just the gasket replaced but if that can't be done, then just replace the shifter assembly.
However, if the entire tranny has to be replaced, I'll see if I can just pull out the broken gasket pieces.
