relumalutan
Arrived home from work, turned off the car. Tried to turn it on after 5 minutes, the key turns only one position. When I remove it, it doesn't go back as far as it used to do, to lock the steering wheel. Car is a DSG, gear selector is in park, the steering wheel moves freely with the key removed. I've sprayed some WD-40, and was able to turn it all the way only once, now it won't turn again.
Trying to save some money here, can anyone tell me how much I can tackle myself of replacing the key cylinder (I'm assuming that I will need to buy it from dealership, and the key will also need to be reprogrammed)? I've found some threads on vwvortex, but the picture links are dead.
Thank you.
Thank you.
