CodyPD06
Hey guys. Pretty new to TDI's. Know very little about them . But I'm not new to diesels. Anywho I've got a 06 jetta. Just had the timming belt kit done and had #4 injector replaced and new cam and lifters.
Car takes for ever to crank up when cold and the glow plug light only stays on for about a second. Dunno if that's normal or not as far as the glow plug light goes, but I'm sure that it shouldn't start this bad when cold. It also has a rough idle when cold. Seems to go back and forth between rough and smooth idle quite a bit before its warmed up, then it idles just fine. Any thoughts on this?
