TurboModified
Before you ask, YES! I've done my research. Still haven't found anyone whose had a solution that worked. My vacuum pump is leaking oil all down the back of the engine and on the ground. Even has gotten on to my flywheel and makes my clutch shudder bad in the mornings (something I will eventually have to replace). So I bought brand new o-ring gaskets, replaced the one that separates the 2 halves and the one that goes b/t the head and pump. The leak is at the bottom back side of vacuum pump where it connects to the head. I meticulously cleaned everything, bolted it back together and leaked. Tried lightly sanding with fine grit to make sure gasket had a good surface to cling to. Still leaked. Tried permatex black, still leaked. Tried permatex gasket dressing, still leaked but not quite as bad. Do these pumps warp after 200k miles that makes them impossible to seal or what? Cannot figure this one out. Thanks for any tips or advice on what has worked for you.
