I tried to get a vag-com but couldn't
The scan guage shows no rpms when cranking either.
The rpm guage did jump a little when I was cranking, it twitched a little, went up and then came down to nothing.
That seams like a wiring or sensor issue right?
I found the sensor...... does the wire pop right off of the sensor or do you need to remove that weird little bolt to get it off? Shall I just replace the sensor or do you think it is the wiring? I made sure the connector up a little furthur is good. How can I test this?
