Old October 28th, 2008, 15:23   #1
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Default ALH vacuum pump outlet loose
Symptoms: (very) occasional bouts of vacuum loss (once in a blue moon the brakes "disappear"... last week there was no boost for about 3 minutes... I could not duplicate any of these events at will...
I went to look at the vacuum system, and found that the hose coming from the pump was loose, so I proceeded to replace the clamp - and discovered that the outlet nipple was not fixed in place.
Is this normal or is it suppsed to be firmly in one position ???
Yuri.
ymz is offline   Reply With Quote
Old October 28th, 2008, 16:52   #2
paramedick
paramedick's Avatar
Yuri, the outlet on the vacuum pump normally rotates. Any other behavior is not normal.
Old October 28th, 2008, 16:58   #3
ymz
Yes, it rotates, but I could also "shake" it from side to side a bit...
Perhaps I'll see if I have some method of checking the amount of vacuum and try to shake it while reading... perhaps my Harbor Freight MityVac clone will do... if I can find an adapter...
Yuri.
Old October 28th, 2008, 19:28   #4
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Yuri its normal...keep looking for other causes.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old November 1st, 2008, 08:40   #5
craig01b
craig01b's Avatar
TDI(s): None
Hey Yuri, i have a vaccuum pump and line from my old engine if you need to replace it. It rotates, but should be fairly tight, without much side movement.
Craig
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old November 1st, 2008, 09:03   #6
ymz
Thanks! I've been too busy even to leave the house to test out the system...
I'll keep this in mind...
All the best,
Yuri.
Old November 5th, 2008, 13:58   #7
morenc00
Fuel Economy: 5.8L/100km winter 5.1 summer
I have a similar problem on my 01 tdi with high mileage, sometimes the brake pedal is harder, sometimes there is no boost and sometimes the anti-shudder valve does not activate when I shut down the engine. I also noticed that my fitting on the vacuum pump is pretty loose (sideways movement). I just made few phone calls and discovered the vacuum pump is not cheap 280$ cnd + tax and not readily available. I also looked at tdiparts.com and they sell the vacuum line and the vacuum reservoir not the pump I guess it's usually the reservoir or line that fails.
I will need to check if it's the problem in my case
morenc00 is offline   Reply With Quote
Page generated in 0.15445 seconds with 10 queries
[Output: 75.70 Kb. compressed to 65.15 Kb. by saving 10.56 Kb. (13.94%)]
