Old October 2nd, 2019, 10:34   #1
Hatchet Ratchet
Hatchet Ratchet's Avatar
Fuel Economy: 52.1 Best
Default BEW PD KP-39 Smart actuator Stop Adjustment
i replaced the cartridge in my 2004 BEW KP-39.
what position should the mechanical stop set screw be set at for the position of the vanes when the actuator is fully pulled down? the lever arm on the vanes also bottoms out on the cap screw that mounts the smart actuator to the turbo housing, so somewhere there or above is what i would presume to be correct?
how do you know or where can you measure from to know if your set screw is at the correct position to limit the bottom end of the vane position?
"If it isn't broken, of course we're going to mess with it, we're men aren't we?"
SPEC Stage I Clutch
Inmotion Stage 2 Chiptuning
1500W Zerostart Heater
"Hatchet Hitch" - 2" Stainless Steel -
"Those willing to give up a little liberty for a little security deserve neither security nor liberty." -Benjamin Franklin
Hatchet Ratchet is offline   Reply With Quote
Old October 2nd, 2019, 11:59   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Don't see much with this, guessing it's not critical. Put a vacuum pump with gauge on to get actual numbers, adjust as needed.
Old October 3rd, 2019, 15:39   #3
Hatchet Ratchet
i haven't been able to find anything referencing the KP-39 Smart actuator and what to set the rod and the stop screw locations to. can you please elaborate on how to set them?
SPEC Stage I Clutch
Old October 4th, 2019, 04:12   #4
Tdijarhead
Curious as to where you bought a new cartridge for your Kp 39?
I’ve never had to adjust the actuator before.
Tdijarhead is offline   Reply With Quote
Old October 8th, 2019, 22:40   #5
Hatchet Ratchet
Iíve never had to adjust the actuator before.
i got the cartridge from ebay. came with a balance and test sheet as well.
made in china.
https://www.ebay.com/itm/KP39A-0026-...72.m2749.l2649
SPEC Stage I Clutch
Old October 8th, 2019, 22:43   #6
Hatchet Ratchet
i have a bunch of errors and i'm not sure which were from before the fix and now after. my first test drive out yeilded very weak power and very little boost.
this is the result of the test drive. any help would be wildly appreciated. i havent' driven my car for most of the summer as i've been dealing with the wrong cartridge or needing this or that for it and just a failure circus.
VCDS-Lite Version: Release 1.2
Tuesday, 08 October 2019, 23:42:01.
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55 ,56,57,75,76
Address 01: Engine Labels: 038-906-016-BEW.LBL
Controller: 038 997 016 L
Component: R4 1,9L EDC G000SG 3791
Coding: 0150031
Shop #: WSC 02651
VCID: 2721789FD6F5
4 Faults Found:
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 000 - - - Intermittent
18996 - Shareware Version. To Decode all DTCs
P2564 - 000 - Please Register/Activate - Intermittent
16627 - Shareware Version. To Decode all DTCs
P0243 - 000 - Please Register/Activate
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00028
VCID: 33199CCF122D
No fault code found.
SPEC Stage I Clutch
Old October 9th, 2019, 10:27   #7
wonneber
Don't know if the 2004 BEW is the same but for the 2003 ALH you want the arm to start moving at 3 inches and be full at about 20 or so. (+/-)
One of the blocks in VCDS will cycle the actuator.
Don't recall which one, someone here may comment.
Tee into the hose going to the actuator with a vacuum gauge or pump.
Start the car. Mine had 12 inches (or so) vacuum and dropped off when I took off.
Yes this sounds backwards.
Did you verify the vacuum pump is producing 20 inches vacuum?
Old October 11th, 2019, 10:38   #8
Hatchet Ratchet
Smile on the road again
i identified the problem. it is somewhere between the seat and the steering wheel. the same source of the problem was also pulling the wrenches.
i cleared the codes and hooked in a tee and a vacuum gauge at the N75 to the smart actuator line. got no vacuum reading.
when i replaced the check valve in the vacuum lines, i put the replacement generic part in reverse of what it should have been between the vacuum reservoir and the rest of the lines.
with the engine running, i pulled that check valve off and immediately heard the vacuum pump purring. at that instant i knew where i screwed up.
when there's no vacuum being pulled on the system, it really can't pull on the smart actuator.
i may adjust the stop screw on the actuator arm to see if allowing it to move the vanes any more produces any more boost or will move me into the overboost condition?
the good news is i'm back on the road and running with my new turbo cartridge, intercooler, intercooler piping seals, and inspected my camshaft for wear from running low on oil when i sheared my impeller shaft at the exhaust side of the turbo.
the bad news is i feel like an idiot for putting the check valve in backwards.
- trace the lines, and put it in the right way dummy.
SPEC Stage I Clutch
Old October 11th, 2019, 20:30   #9
wonneber
Two things.
First, glad you got it working and posted the resolution.
It may help others in the future.
Next, why mess with the turbo adjustment if it's working OK.
If you set it to give more boost you may get over boost limp mode and it won't give more power.
You need more fuel for more power.
Old October 16th, 2019, 11:03   #10
Hatchet Ratchet
i'm watching my fuel economy currently i am thinking that it is on the low side after getting it all fixed up. the actuator adjustment may not be coming in early enough and requiring more fuel consumption to create the boost needed. am wondering if my turbo isn't working hard enough at cruising speed to get the fuel economy i was getting prior to the impeller shaft failure.
i guess if i create an overboost condition i'll know where i have to turn the actuator stop in a bit. ?
Originally Posted by wonneber View Post
Two things.
SPEC Stage I Clutch
Old October 18th, 2019, 20:03   #11
wonneber
In VCDS log group 011 and go for a ride.
It will display boost request & actual.
They won't match exactly but should be close.
Group 011
Charge pressure control warm/full throttle/3rd gear @ 3000 RPM
Engine rpm
Specified MAP: 1850-1950
Actual MAP: 1700-2080
MAP Valve DC: 45-95
WTB: KP-39 bew turbo smart actuator vwnathan Private TDI Items for Sale/Wanted 2 July 29th, 2016 12:54
FS: BEW actuator for kp-39 jonferns Private TDI Items for Sale/Wanted 3 May 16th, 2015 18:42
Wtb: KP-39 BEW PD MrRizzmeister Private TDI Items for Sale/Wanted 2 March 16th, 2014 06:44
WTB: BEW KP-39 Turbo with Smart Actuator (or Just the Actuator) barelybenjamin Private TDI Items for Sale/Wanted 4 December 21st, 2013 16:47
KP-39 BEW PD turbo removal/installation? AudiLikeA4 VW MKIV-A4 TDIs (VE and PD) 5 October 12th, 2010 15:45
Page generated in 0.15086 seconds with 11 queries
[Output: 109.97 Kb. compressed to 94.01 Kb. by saving 15.96 Kb. (14.51%)]
