Old September 13th, 2018, 21:04   #16
Muskrat619
I’m sorry guys got busy with wedding stuff just got married woo hoo!! Lol but it’s only at 3krpms. now it starts to blow white stinky smoke if I let it sit and idle. was getting 50mpg now only 44mpg all vag-com readings are stable and in spec. If I do a diesel purge or run diesel injector cleaner in it it stops temporarily. My injectors were leak tested,pressure tested , pop tested and then cleaned by J.G. Parks in marydel md. Manual transmission conversion 325k on the car. I have not changed the injectors only nozzles. I am not sure if past owners had them replaced or not. Egr delete
Muskrat619 is offline   Reply With Quote
Old September 15th, 2018, 20:34   #17
Franko6
White smoke when cold is diesel. White (actually blue) smoke when idling is going to be a bit more of an aggravation... it's an oil control ring. Usually you can spot it if you run the car for lots of idle smoke, then turn it off and remove the cylinder head. Yeah, you have to pull the head. It's a ring issue. The offending cylinder will usually have a lot more of a wet look on the piston crown.
As a matter of fact, I had exactly this same issue when the #2 oil control ring got all gummed up and quit working at about 240,000 miles. It would get great economy and run hard and fast, but was a mosquito-killer at idle and low city driving speed. It would burn no oil at highway speeds. That's oil control ring classic symptom.
With my own, I replaced all the piston rings, ball honed the cylinders and did some of my 'fix up' stuff, like a Stage II cam, ported head, I like the 502 Firad nozzles against a VNT-17 turbo, Stage 3 or 4 tune... it's fun but not crazy.
Oh, but now that you have a wife, you can't have a performance car. You know, that's part of their rules, right?
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Diesel injection pump test ?? Help Boriquakid TDI 101 3 September 6th, 2013 22:39
How to test a fuel injection pump Boriquakid TDI 101 3 August 3rd, 2013 21:35
How do you test a used Injection Pump??? ItsADiesel TDI 101 3 June 21st, 2012 17:47
Bench test an injection pump? sweetjeep TDI 101 6 January 15th, 2010 08:48
how to test the injection pump and sensors? megaladon6 TDI 101 4 August 10th, 2008 07:26
Page generated in 0.14284 seconds with 11 queries
[Output: 54.20 Kb. compressed to 50.18 Kb. by saving 4.03 Kb. (7.43%)]
