buckinjacket
Hello Folks, I recently replaced the engine in my 04 B5 with another from a salvage yard. When the motor was installed but before assembling the rest of the car I purged the air from the fuel system through the glow plugs according to a post I read only got fuel from #4, installed the glow plugs and the motor started with a stumble then cleared up and ran fine, starting without issue multible times. Now after completing the assembly it will not start cranks, over fine I have removed the glow plugs to see if maybe the fuel system leaked down and there is nothing coming out during crank. Car has new fuel filter replaced tandem pump with one from previous motor Vagcom ran lift pump several times good flow of clean fuel, bypassed tee at filter still nothing. Sorry for long post but wanted show what was done with hopes of someone having an idea of something else to try as I'm at my wits end. Thanks
