sorry i fixed it i hopeCan't see the codes, they sort broken.
Sent from my Armor_2 using Tapatalk
thats what i though, but for some reason its shutting down, but the the brake sensor code was there when it was in the car and it drove fine, the speed signal isnt hooked to anything, but this is my first automatica so im not sure what is needed vs the standards that i normally do.I see the upper picture and nothing stands out as would shut it down.
I don't like the brake signal implausible though, and speed signal to high, seems like they're switched out something
so when checking the 109 relay, i found a power wire that wosnt connected. so now it runs good and ready for the swap.Check the 109
