Posted this over on VW Vortex. My 2006 Jetta TDI must be a vehicular hydra. I fix one electrical issue and three more appear. Using VAG scan tool for codes and such. Replaced the CCM and a few fuses. No comms with previous CCM, but now door locks and both front windows work. Rear motors are likely fried. Getting all kinds of intermittent faults. Ignition switch doesn't register key removal, so I have to lock the car manually. Three doors lock when I do this, except left rear, and - get this - the fuel door opens. Neither the fuel door nor the trunk open via the main door switch, of course. The TPMS light came on, so I inflated the tires to 36 psi and tried to do the manual reset (parking brake on, ignition ON (not RUN), hold down Stability Control, wait for chime) and I got all kinds of rapid ticking, gauges flickering, stereo won't turn on, and car won't start. ***. Waited 40 min, unhooked the battery, etc. and nothing has changed. Oh, and the passenger air bag check light (gauge cluster) won't turn on during initial startup (the one center dash works). I'm about to light this POS on fire.
Used the manual relearn recommended here: https://www.ateq-tpms.com/en-us/article/volkswagen-jetta-2006-2019/
