LiteW8: This is of course one opinion about a prefered car. The 2.0 is ordinary? I think thats a very good thing. Under perfoming? Mine performs quite well. Gas guzzling? I think I will hit 350 miles per tank when I final empty it. I garantee that the price you pay for desiel and additive and repairs, you will lose more than you gain.
The 2.0 liter does perform well, when revving it to 5,000 rpm. Gas guzzling actually the 2.0 liter with an automatic will get almost 30 mpg, my TDI Automatic on a bad day will get 45. Fuel additives do help both engines, but gasoline engine tend to have get clogged injectors due to certain fractions of oil not being fully distilled out and the lower pressure sytems (30ps verses 19,000 in a TDI), diesel engines are not harmed by these contaminants.
If you want to compare apples to apples the fact is the diesel is the only engine that approaches true perfection in thermal and mechanical efficiency, the gasoline engine never will due to aftercooling (richer than stich. mixtures).
Facts be the facts the 2.0 liter is a reliable engine it does not produce a lot of torque but it can rev higher so therefore it does have a higher HP rating. But if you do the math the TDI produces more HP all the way up to 4,000 rpm but who really drives at rpms higher than that anyway? if you do you probably are better off not getting a TDI because you just want to destroy the engine rather than operating it for it's true designed life of 750,000+ miles, a 2.0 liter is around 300,000 if you really take care of it.
As far as maintanence is concerned on the TDI you have to change the timing belt (60,000 miles), no big deal ($64.00 from the dealer) add labor and of course it can get expensive when you pay shop rate. The 2.0 liter still has a timing belt due at 100,000 miles same price to do that one assuming the dealer is familiar with TDI's if not do it your self (it takes 2 hours).
LiteW8 I realize your only purpose here is to create flames but if you don't like diesels or truly feel that your less than factual statetements belong here I say take your planet sized ego and your sack of testosterone and return to the Vortex.
DB
[This message has been edited by Drivbiwire (edited November 16, 2000).]
