Old Yesterday, 11:07   #16
fastalan
Originally Posted by icrashcars View Post
Update
I installed the ECS locking collar kit and replaced the upper and lower dogbone bushings.
There is a noticeable improvement. There is still some movement/ thump, but it is minor compared to before.
I like to ask how easy, or shall I say how hard, was it to press out/press in the two round mounts (the two round rubbers mounted inside the subframe cradle).
I don't have a hydraulic press but was thinking of using some wood blocks, regular car jack and a round steel object slightly small then the rubber, then press the rubbers out against a truck frame.
2k10 Golf TDI Wagon 6-sp manual
2k06 Mini Cooper CVT
1994 Aerostar cargo
fastalan is offline   Reply With Quote
Old Yesterday, 11:43   #17
icrashcars
TDI(s): B5 A4
It took me about 60 minutes.
Removed Subframe
Cut out old mounts with as jig saw
I used a bench grinder to take a little of the material off the edge (lip) of the mounts so they were more tapered.
Froze the mounts in the freezer overnight.
I used a manual wheel bearing press I have. I bought a thinner/ longer bolt that would fit through the centers of the mounts. I really only used the metal press plates, so could prob fab something.This
I was able to press them in about 75% of the way. I then whacked it with a hammer and it popped right in.
The key is the grinding of material to make tapered edge. Remove as little as possible. Also taper the edge of the opening where the dogbone fits in.
icrashcars is offline   Reply With Quote
2015 Golf Sportwagen TDI SE 6MT f0rum TDI Cars for Sale/Wanted 0 February 13th, 2016 17:25
FS: 2014 Jetta Sportwagen TDi, nav, Pano, 6MT Boostaddiction TDI Cars for Sale/Wanted 0 July 11th, 2015 19:11
Nutty's 2015 Golf Sportwagen SEL TDI 6MT Nutty 5.0 Golf TDI Picture Gallery 19 June 12th, 2015 16:12
WTB: 2010-11 Jetta Sportwagen TDI 6MT XJCoupe TDI Cars for Sale/Wanted 2 September 7th, 2014 19:42
Lift throttle thump bpogi VW MKIV-A4 TDIs (VE and PD) 4 May 25th, 2011 06:41
Page generated in 0.10563 seconds with 12 queries
[Output: 56.17 Kb. compressed to 52.08 Kb. by saving 4.09 Kb. (7.29%)]
