skinnedknuckles
I have a 2003 Jetta with an ALH engine. It started making bad noises when I shifted gears and the turbo stopped working so I had no power. The part of the lower motor mount that connects to the transmission with 2 bolts. One of the bolt cracked the tapped hole in half and fell out somewhere on the road. I'm thinking the only way to fix it would be to replace the transmission housing. Currently I have 261k on it. Click on the link below to see the video.
Video of movement
Video of movement
