Jortiz8777
does any one know where i can get instructions on how to swap out the injector pump. i cant seem to find any.
Thankx
Thankx
I recently refurbished my 85 turbo pump. Kit was $18 +-. In order to replace the head o-ring I would suggest removing pump and standing vertically in bench vise. The seal kit was not hard to do if you have medium/high mechanical skills.Real_Diesel said:Just found this thread! Great right up! I have a question. I just picked up a 78 rabbit and got it home this morning (it's been sitting for a while) and it just cranked. I broke the injector lines loose, bled it and she fired right up! But, I noticed the Ip is leaking. It appears to be leaking from the back of the pump. It appears to be leaking where the distributor head mounts to the body. From what I've researched, it looks like it's just an o-ring that seals it. Does anybody know if I can remove the 4 bolts from the head, slide the head off, and just replace the o-ring with no plroblems?
Thanks!
Sometimes the timing belt cover clip sometimes comes off the cover and will hit the alternator fan.mirk said:WOW, great post! I am complete newb to diesels and tdi's and hope to find lots more info like this on Fred's.
I am currently dealing with what I think to be a failing IP. It is making a LOUD clicking noise at engine startup that seems to stay in time with engine rpms. I am sure it is IP as I have used screwdriver stethoscope and localized noise to IP. I have looked over many many threads trying to determine what is happening here. Could this sound be related to rollers on camplate? I dont see them in any of the diagrams, but assume they are inside the roller ring. If so, does this definitely mean replace the pump?
I have already had the IP timing adjusted by local guru due to hard, smokey starting. This fixed the starting, but this is when I noticed the noise (after learning more about the pump and whatnot). Could have been there since I got it and just thought that was how it was supposed to sound as I have no previous experience.
Oh yeah, this is 2001 jetta, ALH w/ 73k miles. This seems very early for IP failure. I just got the car about a month ago and have put less than 500 miles on it. It came from former club member, has the plate frame and all. I believe the story goes that he passed away and his kid got it and kind of beat it up a bit. (No disrespect intended towards any party) Has lots of service records (dealership) so I thought it was a good buy.
Any help in understanding what my next step should be would be very appreciated. I am hesitant to put another $2k into it and my wife is starting to hound me that I got taken. I am starting to think she is right. Sorry to be long winded and thanks for the help in advance!
http://forums.tdiclub.com/showpost.php?p=2253184&postcount=5Nealio said:Is there a website or a thread on this forum that lists the approx cost of different repairs.
I need my Injection Pump replaced and I've been quoted $2000 for the job; about $1400 for the parts. Is this in the right ball park. Seems so, from above messages, but still would like more data points. This is for an 03' Jetta TDI, about 75K on the car. Timing belt recently replaced.
More than likely they screwed up the belt install, and are now blaming it on the injection pump. I can't tell how many times I have seen this and it ended up being something as simple as not setting the injection timing properly resulting in Quantity adjuster codes being thrown.Nealio said:Is there a website or a thread on this forum that lists the approx cost of different repairs.
Who did the recent timing belt work? Maybe it jumped a tooth?TaylorM said:i was driving on the freeway at about 60 and my engine died out and smoke started coming out of the exhaust pipe. When i pulled over i couldnt get it started. I had it towed to a friends shop. They took a day to take it apart and look at it. They said the injection pump is not working. They just dont know why. The only way they think to fix the problem is to replace it. I read about the seals going bad and such but mine is not leaking. My timing belt was recently replaced too. Any advice on what would cause the IP to just not work? any recommendations on what to do. Im contacting a bosch shop and seeing if they will just do a rebuild but im not even 100% sure it IS the IP.
Worst case scenario here: The timing belt jumped time, but a new or rebuilt pump is installed, belt is timed and installed correctly, taylor drives away happy.TornadoRed said:Who did the recent timing belt work? Maybe it jumped a tooth?
Tow it to Wild Rose in Whittier. No criticism of your friend intended, but he does not have the broad TDI experience of Leonard and Scott. It would be a shame to replace or rebuild the IP and then find out that the problem was elsewhere.
I used to travel up there from San Diego, 100 miles each way. On a few occasions I let local shops work on my TDI. A couple times I regretted that decision immediately on seeing the invoice and the dollar number at the bottom. Once I regretted it about 20k miles later when one of the parts they installed failed and wrecked my valves. But I never had a reason to complain about the service or the price when I went to Wild Rose.TaylorM said:please give me some advice who to see. I keep hearing about wild rose in whittier the only problem is im pretty far away from there. No one closer??
So, you want it fixed right... but you are taking it to someone because he's the father of a friend, though he may not know a thing about TDIs?TaylorM said:Im done screwing around. I want it fixed and fixed right cuz im keeping this car for a very long time. I bought it to save me money on gas and commuting if i keep spending money on fixing it then there is no point. So im just going to get it fixed right. (snip)
i have been going to him forever for my other cars and i grew up with his son. Hes a smart guy but i dont think he knows anything about TDI's im sure he has worked on diesels before but i dont think TDI's
