BEW (according to PO).
HP? No ideal.
ECU label (what is the Bosch version number?) from VAGcom scan:
Part No SW: 038 906 016 Q HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 6110
Revision: 12345678 Serial number: VWZ7Z0D0367493
Coding: 0150034
VIN lookup:
Body style:HATCHBACK 4-DR
Brake - front
isc
Brake - rear
isc
Brake system:4-Wheel ABS
Cargo volume:18.00 cu. ft. / 509.7 liter
Consumption in the city:32 miles/gallon / 7.4 liters/100 km
Consumption on the highway:43 miles/gallon / 5.5 liters/100 km
Curb weight:2972 lbs / 1350.9 kg
Driveline:FWD
Engine type:1.9L L4 SOHC 8V TURBO DIESEL
Fuel tank:14.50 gallon / 54.9 liter
Ground clearance:5.10 in / 13.0 cm
Overall height:56.70 in / 144.0 cm
Overall length:164.90 in / 418.8 cm
Overall width:68.30 in / 173.5 cm
Standard seating:5
Steering Type:R&P
Tires:195/65R15
Trim level:GLS 1.9 TDI
Turning Diameter:35.80 ft / 10.9 m
Wheelbase:98.90 in / 251.2 cm
