CR injectors
dieselherb1
Va.
06 MK5,09 Mk5 CR,03 Mk4,96,2-97 B4s,98 A3,2000 A4,4 Caddies( 2-1.6TD,1.6,TDI) Chevys 6.2,6.5,6.5TD
Are there larger CBEA CJAA injectors available?
1854sailor
Resident Curmudgeon
Westerly, RI
2015 Golf SE SportWagen, 2015 Golf SE Hatch Back.
Check with Ryan at Darkside. He does crazy things with CRs.
travis45
Wisconsin
14 Sportwagen, 96 Passat TDI Sedan
Yes, Darkside has them. My understanding is that they allow for shorter injection duration with more fuel.
dieselherb1
Va.
Just checked there. $650 ea for stage 2, WOW!
B3n
Germany, NRW
Passat B7 2.0 CR TDI, B6 2.0 CR EA288
What injectors are inside the CJAA? I replaced my CFGB engine injectors by the newer 2000 Bar version from Bosch. I found out that they release more fuel when same timings are used.
travis45
Wisconsin
B3n, can you please provide a part number for those new Bosch you mentioned?
mrchill
TDIClub Enthusiast, Super Secret Diesel Ninja Vend
MASS! home of THE WORLD SERIES CHAMPION RED SOX! x
96 B4v red \ 98 Mk3 green\98 Mk3 Jetta black\ 99 Mk4 Jetta green x2\ 99 Mk4 Golf silver x2\ 99 Mk4 Jetta black\ 97 B4 sedan green\04 JSW gold\03 JSW silver
The places that mod the injectors insist on new injectors to start with. This is one of the reasons why they are so expensive.
B3n
Germany, NRW
travis45, 04L130277AE 0445110471 but you need to adjust timings in software when using them. otherwise you get black clouds when accelerating ;) i also broke one while using the wrong timings but i don't know its because of that or if it just was a bad used injector.
B3n
Germany, NRW
i found a few pictures of the engines. it seems CJAA is similar to CBAB EU version with Bosch Piezo injectors. My engine is more like the CKRA from 2012-2015 US Passat. So i think these will not fit the CJAA
