Old July 20th, 2012, 11:22   #76
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
DMF replacement is more of a noise issue that represents a flywheel that will need to be replaced soon.
If it's not shifting smooth, I would reset the adaptation. From what I've read, and done, the trans software adaptations should be reset very 40k, when you change the DSG oil.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old July 21st, 2012, 08:29   #77
volkswheels
volkswheels's Avatar
Fuel Economy: 46mpg Winter/57mpg Summer w/Lucas Fuel Additive
Should be the same as a '06.
QUOTE=d12diesel;3840784]Hey guys, I'm new to the TDI circle of owners. I recently bought a 2009 Tdi at an auction and it has that same problem you described (noise from flywheel at idle and hard downshifting from 3rd to 2nd and sometimes to 1st.
Car has 93,000km on it at this time. I plan on doing the job and replacing the flywheel sometime this week. Most of you talked about the 2006, but do you think the process will be pretty much the same on my 2009 TDI automatic? I will be doing it on jack stands.[/QUOTE]
volkswheels is offline   Reply With Quote
Old October 30th, 2012, 22:00   #78
57ringo
57ringo's Avatar
I started to take things off and the bolts on the DSG heat exchanger were way too tight. I barely got the outside one broke loose and the inside one stripped out. So do I weld a nut on it and get it out now?
2006 Jetta TDI
2005 Dodge Quad cab 4x4 CTD
1992 KW T800
several John Deere's and more
http://www.youtube.com/watch?v=PnlxN0aT_ys
57ringo is offline   Reply With Quote
Old October 31st, 2012, 06:59   #79
TonyJetta
Try a bolt-out kit, like this. This is the bigger kit; there are smaller and cheaper kits available.
Tony
Old October 31st, 2012, 11:28   #80
57ringo
57ringo's Avatar
Thanks Tony.....used one of those and hit it a few times with a hand impact and broke it loose. I'm not a fan of allen head type, 12 point or these triple square bolts...wish they were all hex head. They either come loose or twist off..none of that stripping out or rounding off.
2006 Jetta TDI
1992 KW T800
Old November 3rd, 2012, 08:51   #81
57ringo
57ringo's Avatar
What is the torque on the bolts in the crossmember (front, back, torsion bar & rack)& the ones in the A arm/dogbone too?
2006 Jetta TDI
1992 KW T800
Old November 4th, 2012, 08:40   #82
57ringo
57ringo's Avatar
On your forth photo ( mounts laying on the tire)....what is the torque for the three 12mm bolts that bolt the mount to the block and what is the torque for the 4 smaller bolts ( one has a stud on top) that hold the block on the transmission? What is the torque for the 4 bolts holding the rack & pinion on and the 4 smaller ones holding the torsion bar in place?
2006 Jetta TDI
1992 KW T800
Old July 27th, 2016, 06:14   #83
Supergazoo
hello, just recently purchased an 06 tdi with the DMF rattling. the diy write up looks really good...but i am wondering if any one has the orgional photo's with the write posts on them. the ones on here are un-readable. and does anyone know where i can get a new one for less then 625 bucks in canada? thanks.
Bruce
Supergazoo is offline   Reply With Quote
Old July 27th, 2016, 14:46   #84
ecaddy
I do not see an attach option on here. Sorry
ecaddy is offline   Reply With Quote
Old July 27th, 2016, 19:17   #85
meerschm
meerschm's Avatar
I can see the photos.
I think original photos are here
http://pics.tdiclub.com/showgallery....0&ppuser=68036
(might have to log in again)
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old July 30th, 2016, 04:57   #86
Supergazoo
got it thanks.
Page generated in 0.14223 seconds with 10 queries
[Output: 100.71 Kb. compressed to 84.75 Kb. by saving 15.96 Kb. (15.85%)]
