That's pretty close to my calculations made 12 years ago here:@ Jukums:
Which boost pressure sensor do you use? For 400 PS you need 5 bar, 5000mbar absolute pressure to drive lambda 1.2 and over 140mg / h injection rate. Your 4 bar boost pressure display is not enough. And you need an air mass of 2500mg air for 400 PS.
I used 6bar map sensor from truck@ Jukums:
Hi guys) harness should be from +99.you were totally so close with the earlier AFN engine build, hope to see this on road soon! you are great sir.
E: btw ive done the same 130pd block + alh head on b5.
i did my own wiring harness using passat pd harness + VE pump harness. i was NOT aware that A6 comes with EDC15VM+ from the factory with the right plugs to fit B5!! Just make sure the car youre working it on is +97 with not the round plugs, but the normal looking plugs in the cabin side.
