hey guys,
i have a 09 golf (mk6) and the sunroof drain is leaking inside .. i can clearly see that when i pour water into the drain it leaks on the drivers side (left) on my left corner, it comes from somewhere behind the dash
does anyone have the sketch of the sunroof drain lines (tubes) so maybe i could find out where it was disconnected ?? also if its a common problem (with this specific location) if someone had it fixed and could give me a game plan that would be great! thanks you guys!!!!
