UFO said:
Viton is too expensive. It runs more than $10 a foot in 5/16 or 3/8 sizes. Try to get some metal lines formed, or better yet, just put biodiesel in your regular tank.
copy of mcmaster-carr page for this size hose. if incorrect go to mcmaster-carr. keyword viton. tubing at bottom of the page. i did see one wvo mb190 with the clear hoses. looked cool watching the oil flow. couldda stood thatere all day had i been stoned. this fella had colorer lines on his to tell if the oil was going or coming.
View catalog page
Compare products (4)
Tubing
4 products match your selections
RubberVitonMaterialVitonShapeSingle LineSystem of MeasurementInchOutside Dia.5/16" (.3125")Inside Dia.1/4" (.25")Wall Thickness1/32" (.0312")ReinforcementUnreinforcedMaximum Pressure Range, psiNot RatedLow Temperature Range-99º to -1º FHigh Temperature Range+301º to +500º FOperating Temperature Range-15º to +400º FPerformance CharacteristicsOzone-Resistant and UV-ResistantBend RadiusNot RatedFittings UsedBarbedSpecifications MetNot Rated
Color Many plastic colors vary depending upon the consistency of batches, the thickness of the piece, and the viewing conditions. Please use these listings as a general guide. ul#colorul { margin: 0px 0px 0px 5px; padding-left: 20px;}
- Opaque materials block the passage of light.
- Semi-Clear materials are translucent, allowing the passage of light, but not necessarily a clear view of tubing contents.
- Clear materials allow view of tubing contents without significant obstruction or haziness.
Opaque
Black
Brown
Green
Plastic/Rubber Hardness
The wall hardness of plastic and rubber tubing is usually measured on the Durometer scale, though some of the hardest materials (particularly in the structural tubes) are measured by Rockwell or Barcol scale numbers. The higher the number, the harder the material.
Durometer Range
51A-70A (Soft)
71A-95A/22D-45D (Firm)
These 4 products match your selections
DurometerType Per Foot Opaque Black Color
60A (Soft)High-Temperature Soft Viton Rubber Tubing
5119K331-49 Ft.
50 or more
$3.66
$2.93
75A (Firm)High-Temperature Firm Viton Rubber Tubing
5119K8511-49 Ft.
50 or more
3.25
2.60
Opaque Brown Color
5119K8571-49 Ft.
50 or more
$3.25
$2.60
Opaque Green Color
5119K8541-49 Ft.
50 or more
$3.25
$2.60
10 bucks for a meter maybe.
