ROBSTAFF
- Joined
- Aug 2, 2001
- Location
- Richmond Hill, Ontario CANADA
Hey all...
My 96 passat TDI now has a tapping ticking noise coming from the engine. It increses with RPM. It is now changed with synthetic 5w50. The noise remains unchanged. I traced the sound to the first lifter nearest the timing belt area. I suspect it is not getting oil due to crud blockage. I poured in some wynns oil treatment/cleaner this morning and there is no change. Does it work over time??
Any ideas what else i can try before spending the $$$ for diagnosis?
Can I continue to drive without causing damage?
Thanks all
[ September 18, 2002, 12:21: Message edited by: ROBSTAFF ]
Thanks all
