db123
So just finished completing a balance shaft delete, new camshaft and timing belt. Prior to doing this work the car pretty much since last October. I'm having several issues now
1) The tensioner... the pointer was in the between the slot when tightened. Correct tools were used, everything lined up after rotating the crank gear twice. After the vehicle was started the pointer is now way past the slot. Is that normal or is the pointer supposed to stay within the slot?
2) There is oil dripping from the back of the engine onto the ground... new valve cover gasket was used. Valve cover bolts were tightened to 7ft-lbs. Sealant was used in the corners of the 1&5 cam caps. Sealant was applied the the firewall side of cam cap #5 and the tandem pump gasket and I had pushed the #5 cam cap towards the firewall when torqueing the bolts down.
3) When performing the break-in prodedure on the cam, I was experiencing what I would call quite a bit of smoke, at times it seemed to be blackish smoke and at other times blueish.
4) When first started I got an "Emissions workshop" message, but that did go away.
