Jerz
- Joined
- Nov 19, 2013
- Location
- Alberta, Canada
- TDI
- 05 Passat Wagon GLS TDi 180hp, 5 speed swap; 05 Passat Wagon BEW swap (wife's, traded for OM606 Merc soon to be STD); 05 Mazda B3000 2.0mTDi swap (sold); Boxster S TDi swap (under construction)
Here are the codes:
16497 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Temperature: 133.2°C
Temperature: 80.1°C
Temperature: 52.2°C
18000 - Altitude Sensor / Boost Pressure Sensor
P1592 - 000 - Implausible Correlation - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001000
Absolute Pres.: 887.4 mbar
Absolute Pres.: 2182.8 mbar
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 252 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.72 V
Bin. Bits: 00001000
Absolute Pres.: 1132.2 mbar
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 2226 /min
Torque: 0.0 Nm
Speed: 117.0 km/h
Temperature: 25.2°C
(no units): 28.8
(no units): 1.11
Temperature: 68.4°C
16725 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 504 /min
Torque: 234.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001000
Idle Stabilization: 0.0°KW
(no units): 32.0
Anybody's seen this combination?
Freeze Frame:
RPM: 0 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Temperature: 80.1°C
Temperature: 52.2°C
Freeze Frame:
RPM: 0 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001000
Freeze Frame:
RPM: 252 /min
Torque: 102.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.72 V
Bin. Bits: 00001000
Freeze Frame:
RPM: 2226 /min
Torque: 0.0 Nm
Speed: 117.0 km/h
Temperature: 25.2°C
(no units): 28.8
(no units): 1.11
Temperature: 68.4°C
Freeze Frame:
RPM: 504 /min
Torque: 234.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001000
(no units): 32.0
