ZipLock
I'm trying to troubleshoot an intermittent stalling at idle issue with my 2004 PD. I've been working my way down the Investigating PD Injector Issues at Idle sheet: http://pics.tdiclub.com/data/517/PD_fuel_delivery_check.pdf and I think I've found a problem with the fuel rail back pressure regulator.
The sheet says that I should get "no flow" on the return line during the test. When I run the test fuel will gush out for the first 1-2 seconds and then slow to a trickle. Does that mean my regulator failed the test?
Also, if my regulator is failing then is there a way to replace just that component or does the whole tandem pump have to be replaced?
