Old August 27th, 2003, 16:00   #1
DeGolf
DeGolf's Avatar
Fuel Economy: 54.7/48/45
Default Timing belts
I have the OEM 60,000 mile belt (2nd one) and I need to replace it now that I've hit 120k on my 99.5 Golf GLS TDI. However, I see there is a better one (80,000 mile change) but it costs 3x the other at Impex...is it worth it for only 20,000 miles difference?...that is about 9 months difference in driving time for me. What say you...and anyone in eastern CT interesting in helping me do the job who knows how or should I fork over $400 to the dealer?
DeGolf is offline   Reply With Quote
Old August 27th, 2003, 16:21   #2
Herm TDI
Herm TDI's Avatar
That 80K TB kit has all of the goodies...much more than just the TB & tensioner.
To do the job right....that kit is the way to go.
Herm TDI is offline   Reply With Quote
Old August 27th, 2003, 16:29   #3
DeGolf
DeGolf's Avatar
Does the dealership change all the parts or just the belt? What is wrong with keeping the original parts unless obviously defective?
Old August 27th, 2003, 16:34   #4
Herm TDI
Herm TDI's Avatar
Well....for starters..the engine mount bolts are "one time use only".....and many stealerships cut corners...then as it often has happned ...the bolts give way and your engine falls from the mount. Secondly, the stealerships will not replace the cam shaft oil seal....and if they do...then they will jab you with a much larger bill for a simple 10 min job. Lastly...the kit also has the replacement serpentine belt...often the stealership will simply re-install your old one
Old August 27th, 2003, 18:47   #5
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
[ QUOTE ]
[/ QUOTE ]
__. Herm's reply is excellent, I'd add that it's an absolute necessity for the TB tensioner to be changed when the "new - long life" belt is installed. The kit is an excellent idea - it's really the way to go since it has all the parts that you really need. But the dealer "techs" have been known to take people's parts and NOT install them. Whether they plan to keep the unused parts and sell them to other customers, or use them themselves, or if they just are too ignorant or lazy to use them isn't clear but -- if you go to a stealer for the work, demand to see ALL the old parts.
mrGutWrench is offline   Reply With Quote
Old August 27th, 2003, 18:48   #6
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Herm is the man....just listen to me!
POWERSTROKE is offline   Reply With Quote
Old August 27th, 2003, 19:38   #7
GoFaster
Moderator at Large
[ QUOTE ]
[/ QUOTE ]
Wear is not always visible or obvious. Imminent failure (e.g. due to fatigue from long use) is not always visible or obvious. Some component failures can result in damage enormously more expensive than it would have cost to simply change out the part prior to failure.
Old August 28th, 2003, 14:33   #8
RLGuy
To see what's wrong with not replacing all of the parts (and in my case, even if you DO replace them), see my posting 'Timing Belt Hell'. The tensioner was new but broke after 13000 miles...and since I'm the second owner, I'm screwed. Good luck...
RLGuy is offline   Reply With Quote
Old August 28th, 2003, 15:00   #9
DeGolf
DeGolf's Avatar
ok, I'm getting the picture...btw dealership wants $500 for the job and only knows about the 60,000 mile belt.
sooo, who want to help me do this in eastern CT? Any takers? I'm to confident enough to do it myself...I dont have the tool neither. Speak up now
Old August 28th, 2003, 15:48   #10
DeGolf
DeGolf's Avatar
let me clarify my previous post...I do not have enough confidence to do the job myself and I am sure I do not have all the necessary tools...there.
I'm really not as dumb as I seem [img]/images/graemlins/cool.gif[/img]
Page generated in 0.13213 seconds with 10 queries
[Output: 91.20 Kb. compressed to 77.09 Kb. by saving 14.11 Kb. (15.47%)]
