Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old October 16th, 2017, 05:32   #1
BAZ3713
TDI(s): GT TDI
Default Cranking time
Evening all,
I have noticed since I've had my 2.0 tdi GT that when I go out to the car in the morning or even when I finish work that the car takes longer to fire than some other times, but what I Have noticed that the outside temperature is always about 12 degrees when this happens, if it's any colder it starts straight away, what I was thinking is the glow plug system on a temperature sensor, so that the engine will get a heat when outside temperature is lower than 12 degrees roughly.
Has any 1 else noticed this same thing.
Barry 👍🏻
BAZ3713 is offline   Reply With Quote
Old October 16th, 2017, 08:14   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
What year is the car?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old October 16th, 2017, 13:03   #3
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
All I remember on my 2002 Jetta when you put the key in the door to unlock the car, the glow plugs were already started at a certain temperature.
I have no idea how my 2015 Passat works in that regard. Possibly similar.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old October 16th, 2017, 13:21   #4
BAZ3713
TDI(s): GT TDI
It's a 2013
Long cranking time once warm joep1234 VW MKIV-A4 TDIs (VE and PD) 9 December 15th, 2016 20:31
Loooong cranking time mxracer170 TDI 101 9 July 5th, 2013 21:18
long cranking time SCMountainDiesel TDI 101 16 October 18th, 2010 21:56
Longer cranking to starting time. Knoxville TDI 101 23 February 13th, 2009 14:26
any/all extended cranking time causes? megaladon6 TDI 101 15 August 24th, 2008 20:06
Page generated in 0.11755 seconds with 11 queries
[Output: 63.32 Kb. compressed to 56.65 Kb. by saving 6.67 Kb. (10.53%)]
