Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old October 6th, 2017, 05:18   #1
Brauvura
Brauvura's Avatar
Exclamation 2012 VW GLI help please
I have a 2012 VW jetta gli 2.0 turbo dohc 6 speed transmission. We've replaced ignition coils, spark plugs, fuel filter, had injectors cleaned, still runs rough. Engine light blinks a few seconds and then stays on. I haven't driven it in weeks because I dont want to mess it up! We buy only OEM parts. I've talked to people and they think it might be electrical, but it's a guess.
Brauvura is offline   Reply With Quote
Old October 19th, 2017, 19:13   #2
Powder Hound
Powder Hound's Avatar
My advice: 1) find someone with a Ross-Tech VCDS dongle and get a good read on what the ECU is complaining about. That is an order of magnitude better than guessing.
2) This is a diesel forum. While people here like to help, admittedly most people's expertise will be in the are of compression ignition engines, hence the lack of response.
3) You might find better info at vwvortex.
Good luck, and
Cheers!
PH
Old October 27th, 2017, 09:32   #3
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Does it smooth out at all after the engine has warmed up?
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old October 27th, 2017, 09:50   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Intake ports gunked up would be my (very experienced with these) guess.
Very common, I do these a LOT.
You also have to check the crankcase breather valve. Those fail a LOT too.
Where in Missouri are you?
oilhammer
www.cardocautomotive.com
Will 17" VW Classix (GLI wheels) fit on a 2012 JSW? Donkeyshins VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 June 9th, 2013 23:22
Can you buy the 2012 18" GLI rims? extreme202 VW MKVI-A6 Jetta Sedan (~ 2011+) 21 March 17th, 2012 13:07
2012 VW Jetta GLi review LRTDI General VW Discussion 15 December 30th, 2011 07:08
anyone know usa release date for 2012 jetta gli? m379 General VW Discussion 6 August 12th, 2011 06:33
2012 Jetta GLI information fungi131 General VW Discussion 0 April 6th, 2011 11:27
Page generated in 0.11630 seconds with 11 queries
[Output: 64.78 Kb. compressed to 57.94 Kb. by saving 6.84 Kb. (10.57%)]
