Quick update:
I have been fighting the over boosting for some time now and I finally had time to mess with it. I don't have any turbo issues, besides oil leaks down the pipe at bottom and drips, but i think that is all from the intake pulling in oil. It seems the actuator needed adjustment. Even with the the vacuum gauge I could only get 15 in of vacuum, so I just made small adjustments by hand until I could make the check engine light go on and off by just a turn or two. It has held all day today and I am going up a steep pass tonight, so I know it will have a good chance of over boosting just to maintain speed if the actuator isn't adjust good enough.
So I want to add injectors now, do you guys have any suggestions. I want the biggest hp gain with a stock turbo.
