dieselpower04
Makes me wonder about mine then...I get a little white smoke when its cold out, but I think its just fuel. Oh well
The Tuscans are ~600g each w/ARPs, a bit heavier than Rosten's and IE's own H-beamPeter, do the IE Tuscan rods and ASV pistons weigh less than the OE pistons and rods?
That's quite the overstatement. This car spent much of its life at +40% power levels and the rods slowly failed through creep. Peter, what's keeping you from rod upgrades?What's amazing is how with just pp502s, 10mm and I think 5th gear swap? the rods melted. Peter and this car were always for me the standard in conservative tuning.
I see, I was thinking the 'safe' power level was about 170WHP before the engine started to have problems. You would then argue that this number should be around 135HP and with time you would get rod creep. So peak power is not the issue, it is how much the car is driven hard at even lower power. RC6 was mentioned but the car was mainly dynoing well below 200hp.That's quite the overstatement. This car spent much of its life at +40% power levels and the rods slowly failed through creep. Peter, what's keeping you from rod upgrades?
Sent from my iPad using Tapatalk HD
That same tune ran in the rally car for 5 years, and ate a few turbo's (15s/17s), transmissions and axles. It did get rostens at one point during a random teardown/inspection. It survived well. and never left us stranded (well one time at pikes peak = streettoys disaster). But we won that event beating out the factory toureag's time up the hill using the 1752 out of Olivers car that he drove there for a parts car. Jon set a world record for production car / alternative fuel that year - still holds afaik. The car dyno'd at Kaz's motorsport 5500' at 150hp, and 200hp at sea level with same setup. It was estimated to be 90hp at 10,000'. Still got that video of Jon passing the big block factory five race car that was gasping and lumbering up the hill near the top where all the gassers nearly fainted.My best dyno was 185/315. Car was like that for about 40K. During that time I did a bunch of track days. So they may have been bent for a while.
They're new. Chill put the PP520s on them and pop tested them. They were consistently at 190 with the stock nozzles, around 200 with the PP520s. He said the different hole design on the Bosios made them pop at slightly higher pressure.I still have my old Transporter injectors from my A3, nice to know you've found a setup that works well with them. I may have to get those redone some day. Who set yours up?
It would be interesting, for example, to compare PP520s to Race 520s with the flow reduced and see if there's any difference in dyno results or fuel economy. I wasn't willing to experiment with something unknown.
Agreed, which is more important on a higher RPM tune. There just is not as much time to get the fuel in.What I do know is that a bigger nozzle requesting less fuel(same smoke level) has a shorter duration and should make better power...
Perhaps, but since we can't even get most people with tuned cars to get on a dyno, maybe not. I now have a cam in my car that, until now, has no before and after performance data. No upgraded cams do. Same with nozzles.Only if someone could figure out a way to get those snazzy pressure-sensing glow plugs from the CRs into our VEs and PDs. Think of the tuning data we'd have!
I think that with the proper timing and short duration, you can definitely make less soot and probably less NOx while making more power, however NOx is not usually our #1 concern here in the power enhancements sectionOne thing that I'll note is that the short duration approach does create a big problem with soot and NOx production. Not that relevant for our purposes, but it's why the OEMs aren't using it.
12mm and DE143 with upgraded springs will do 5500rpm and give you a lot more pressure for atomization with say an R520 or equivalent nozzle..Most folks believe 10mm pumps like high revs better than 11mms, and 11s like high revs better then 12s. I've learned on the track that over about 5500 mostly what you get from the TDI is heat, anyway.
