Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old August 12th, 2017, 16:24   #7711
[486]
TDI(s): 02 golf ALH
I'll have to go check it out tomorrow morning, thanks for the heads up, I usually only go to jellison's
could use a DE143 camplate, spare pump's a bonus
[486] is offline   Reply With Quote
Old August 13th, 2017, 09:28   #7712
[486]
TDI(s): 02 golf ALH
Only saw the one auto, GPs had been pulled, I got the pump and injectors (for 26 dollars!), drained the IP into the injector holes for anyone wanting the engine.
Still had the head, manifolds and turbo, but 12mm triple square is at work Might talk myself into grabbing the head.
Thanks for the heads up, GG!
ETA: grabbed the head, it had ARPs and I hadn't brought a 9/16" 12pt
luckily I found someone that had one and they weren't all that tight, oddly enough. I'd say like 100ft/lbs max
turbo (minimal shaft play) and shortblock are still there
Old August 14th, 2017, 23:06   #7713
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
nice!!! Good score.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old August 31st, 2017, 14:46   #7714
violentaesthete
Fuel Economy: more than needed but not quite enough
Anyone have a recommendation for a local machine shop to take my spare block and head to? Looking to have a tq plate/bore/hone done and a head cleanup on my spare ALH.
violentaesthete is offline   Reply With Quote
Old September 1st, 2017, 00:11   #7715
[486]
TDI(s): 02 golf ALH
torque plate likely isn't going to be a local thing, not that it's remotely necessary IMO
you'll probably have to get it sent in from a rental place
The only plates that every shop will have are ones where the head bolt bosses are cast into the cylinder walls, like an SBC 400CI. On these motors the bosses are cast into the water jacket, so cylinder distortion from bolting the head on is less than you get from hanging the motor by the engine mounts rather than by a rod through the mains.
Sadly the guy I send work to went to the length of changing the name of his shop to avoid modern car work, as he's already continually swamped with guys doing restorations on ancient stuff. Had a lincoln flathead v12 in last time I was there, very cool stuff.
Old September 1st, 2017, 09:55   #7716
JFettig
JFettig's Avatar
merkerguitars@gmail.com for torque plate
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old September 2nd, 2017, 07:04   #7717
TornadoRed
TornadoRed's Avatar
Very clean Golf TDI just offered for sale in Duluth. https://minneapolis.craigslist.org/h...290102200.html
'03 Golf with 741k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, TDT or Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
Old September 2nd, 2017, 17:02   #7718
TornadoRed
TornadoRed's Avatar
Not only is there a $12.00 per gallon rebate on Mobil Delvac 1 ESP 5w40, but Mills Fleet Farm has a sale on those gallon jugs. Now only $22.99 until September 9th. So $10.99/gallon after rebate.
You will never find a better oil for a better price. I still had 3+ gallons from the last rebate, which just ended 3 or 4 months ago, but I still had to buy four more.
Old September 5th, 2017, 09:38   #7719
violentaesthete
If I can source a torque plate, I may as well use it. I am probably going to end up asking around the heavy diesel places to see what they recommend for a machine shop unless someone here has used someone local. I am more afraid of the head work than the block work but I think I can explain to them that they cant take .040 off like a small block.
Old September 5th, 2017, 14:10   #7720
greengeeker
Originally Posted by greengeeker View Post
Peeps, there are several Mk4 tdis at the Johns auto you pull yard. One is a very complete auto with an 11mm pump.
Another John's Auto (LKQ) update: there a decently complete BEW beetle in the yard (DSG) as well as a couple of picked over-ish ALH cars (the one 486 pulled parts off of already). More importantly I overheard the front counter people mention that LKQ would be closing this facility in December and would no longer be bringing any more fresh cars into the yard. The positive here is the front counter people definitely have a F*CKIT attitude and are letting parts go for super cheap. I walked out of there last weekend with a bed full of vw parts (manual swap parts, hood, door, hatch, door regulator, SAIP...a bunch of little bits) and only had to lay down $100. Anyway, if anyone is in the market for small odds and ends, I would recommend swinging up there.
(I have no affiliation with John's whatsoever )
- Nick -
Old September 11th, 2017, 12:15   #7721
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Any decent engine shop should be able to handle the block, I'd be cautious with the head though. Might be worth shipping it off to Franko6.
I made the mistake of trying an import engine place down in Minneapolis (looks like they are closed now) to rebuild an ALH head. It lasted about 40 miles before the camshaft snapped into 2 pieces. He claimed I torqued down the head wrong and didn't stand behind his work. Well my head from Frank is still going strong over 100k later.
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old September 11th, 2017, 14:28   #7722
84vw
TDI(s): 2005 Golf
Hi everybody. I have a 2005 golf with the BEW that has pooped right in the bed. Still runs enough to get it from point a to b, but it's not long for this world. I would like to just get a known good replacement long block rather than rebuild what's in there.
Does anyone here have or know of someone with a good BEW for sale?
The car has a manual transmission and 200k miles. The previous owner most likely didn't change oil frequently enough.
84vw is offline   Reply With Quote
Old September 11th, 2017, 17:07   #7723
TornadoRed
TornadoRed's Avatar
400k+ miles on my Frank Irving rebuilt cylinder head.
Old September 12th, 2017, 09:53   #7724
violentaesthete
I know the whole forum praises his work, but I have a friend who had a bad interaction (bad head) and to be honest, I would much rather give a local shop some business. We have a machine shop at work and I can take care of measuring and installing everything, and the only thing the engine shop will be taking care of will be the milling and valve guide install.
Additionally, I was given a recommendation on a shop - Metro Engine in New Brighton and will be using them most likely.
Old September 12th, 2017, 20:02   #7725
[486]
TDI(s): 02 golf ALH
yeah, they're who I use, now they're 'dark horse', changed the name to avoid the overflow of work they've been getting
dave does great work if he's the one doing it, had some small troubles when another guy there did the work, but I haven't seen that guy there any more and he's got a new helper.
ETA: oh, and he'll talk with you for quite a while while you're dropping the parts off, real friendly guy.
Page generated in 0.26268 seconds with 10 queries
[Output: 134.74 Kb. compressed to 113.15 Kb. by saving 21.59 Kb. (16.02%)]
