PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
I just had the first light bulb failure in the Jetta, the left tail light. The old bulb is 5 watts. I put a replacement in I had in the "bulb bin", a collection of auto lamps I collected over the years. I think it was marked T-87. I also have a T-67. I can not find specs on these bulbs, even doing a Google search. What is the voltage and wattage of the T-87 and -67? I may have some 6-volt bulbs thrown in the "bulb bin" since I owned a couple of pre-1967 VWs. The bulb I put in appears slightly brighter than the original (as compared to the right side tail light).
One odd thing I noticed when I consulted a Bentley manual (for a 1999-2002 Golf/Jetta) is that the tail light bulb for the Jetta is 5 watts and the tail light bulb for the Golf is 10 Watts, both having the same bulb envelope. Why the double wattage for the Golf? I wonder if I could use the 10 watt bulb in the Jetta for added visability.
--Nate
--Nate
