Not to bring up an old thread or anything...but getting ready to do the wiring on mine. Understand everything fine but all I need to know is...do I need a powered or not powered converter? Thanks
I don't know what you mean by powered or non-powered converter. I did mine this weekend and the converter cost $27 from OReilly's auto parts. They sell them at etrailer.com so i think they are pretty much a common kit.
Included in the kit is the following
1) converter
2) 18" 4 wire extension cable
3) 4 splice connectors
4) screw for ground wire
5) dielectric grease
6) plug for cable
7) LED test cable
I used the Bentley, but if I recall correctly here are the colored wires to know at least from the kit I used (Jetta wire color/Converter wire color - function):
RED/red - brake
GREY-BLACK/Yellow - left turn
GREEN-BLACK/Green - right turn
I can't recall the tail lights color on the Jetta, but the converter wire was Brown. White is the ground wire on the converter.
To run the wires to the hitch I drilled a 7/16 hole and added a grommet. I cut the wires on the extension cable closer to the end near the convertor and spliced after running the wires back through the grommet. I used two zip ties on each side of the grommet to help keep the wires from pulling through and siliconed on both sides.
