Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old June 11th, 2019, 14:13   #1
McGuillicuddy
Fuel Economy: 5.6 L/100km
Default What are my options if I need a new transmission?
Out of nowhere my 5speed transmission will no longer shift into reverse. I've managed to determine that the problem is inside the transmission rather than with the shifter/linkages. I'm hoping that removing/replacing the gear selector tower/bearings or something easy like that will fix it, but in the unfortunate event that a new transmission is required can anybody recommend where to look for a new one? Or any other considerations for such major surgery?
'The Battle Wagon'
McGuillicuddy is offline   Reply With Quote
Old June 11th, 2019, 16:39   #2
steve6
these transmissions are usually pretty reliable, just find a good used one and have a shop swap it in, its straight forward since you already had your clutch changed you dont need to worry about that part.
I have never had one personally fail on me.
steve6 is online now   Reply With Quote
Old June 12th, 2019, 06:21   #3
imo000
imo000's Avatar
Fuel Economy: Good enough
If you want a new one, the VW dealer is the ONLY option.
imo000 is offline   Reply With Quote
Old June 12th, 2019, 06:50   #4
McGuillicuddy
Without having checked, is it even possible to order a brand new one? Mine only has 150K on it so it would be a shame to replace it with a used unit with 300+ on it. Car is at Perjad's today so will learn its fate shortly.
'The Battle Wagon'
Old June 12th, 2019, 11:15   #5
krazykipa
Sure, you're looking at roughly $2K + tax for a rebuilt unit from VW.
EGR (top) vs. EUH (btm)
krazykipa is offline   Reply With Quote
Old June 12th, 2019, 17:14   #6
P2B
P2B's Avatar
I have a used one with 172K on it that I'll part with if you need it.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old June 12th, 2019, 17:50   #7
McGuillicuddy
Simon
Thanks! PM sent.
Had the car into Perjad's today and we are both stumped. We are left with multiple low-probability options:
Reverse gear bad (unlikely because you can still get it into reverse sometimes and there is no grinding or anything). Would require rebuild or replacement transmission.
Shift tower bad (unlikely since no other gears affected). Easy to replace but hard to source.
Reverse selector fork bent (unfamiliar with this but apparently would require a rebuild or swap transmission).
At the moment trying to source just the shift tower/housing since that is the easiest to change. Problem is nobody wants to sell those separate from the transmission, and the dealer wants a fortune for one (more than a whole used transmission). So may have to go the replacement transmission option regardless .
'The Battle Wagon'
Old June 12th, 2019, 18:23   #8
HPsenicka
Contact DasParts in Cambridge... I was asking earlier today about a shifter tower, and the said they had a used one in good condition for $40.
I have a gearbox with what appears to be a badly worn "ballsleeve" that supports the linkage rod in the center of the tower, and was thinking I might prefer to rebuild a spare rather than taking the car out of service while I fight with removal of the old "ballsleeve" bushing.
I have since found a deal on a spare gearbox that I couldn't pass up, so I have some freedom to approach the problem from a couple of angles.
HPsenicka is offline   Reply With Quote
Old June 12th, 2019, 21:07   #9
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Reverse gear is easy to change unless you chewed up the main shaft. Takes about an hour once the box is out on the floor. The old 020's used to break them, but I've only seen it once on 02J. It sheared the mini shaft right off at the thrust bearing.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old June 18th, 2019, 05:40   #10
amit9
amit9's Avatar
Thanks! PM sent.
Did it get sorted out? All good now?
2003 GLS "SilverJet" TDI, Zerostart 1000W, Defender-Tech skidplate version 2
amit9 is offline   Reply With Quote
Old June 18th, 2019, 07:25   #11
McGuillicuddy
Perjad sourced a replacement shift tower for me and that *seems* to have done the job. It hasn't failed since it was installed so I am cautiously optimistic. I say that because I did have brief periods where it would seem to fix itself before, but usually only for a few minutes or so and then it would act up again. Since the new tower was installed yesterday it hasn't given me any issues so it appears to be good so far.
Incidentally it is fairly hard to find a replacement shift tower. Understandably people only want to sell intact transmissions, or want you to pay out the nose to separate. One jackass from Woodbridge who has a pile of VWs being parted out on Kijiji was trying to play games with me but fortunately Perjad was able to find one. Hopefully he is not a member here - if he is we should shun him appropriately.
'The Battle Wagon'
Old June 18th, 2019, 07:55   #12
amit9
amit9's Avatar
Thumbs up
Great, good to know.
Old June 18th, 2019, 20:55   #13
HPsenicka
Curious to know what parts were replaced... did it include the whole shifter rod and receiver that is visible when the top cover of the shifter tower is removed? I have mine opened up at the moment, hoping that I can get away with just replacing the collar/bushng inserted into the cover, and reinstalling with new seals.
I can clearly see some rusty lube where the original bushing was inserted, and am concerned about what contaminants may have found their way into the gearbox case.
Old June 19th, 2019, 04:31   #14
Vindiesel6
Fuel Economy: 42 - 52 mpg
For anyone who truly needs a new transmission, contact Aaron at Cascade German parts.com he has new and remanufactured transmissions for these cars at great prices. I installed a reman 02J in my alh back in December with excellent results. The rebuild quality is top notch and price along with the warranty are the best you will find.
Vindiesel6 is online now   Reply With Quote
Old June 19th, 2019, 07:15   #15
McGuillicuddy
So mine is like the one on the right (notched). The parts that were replaced were the upper housing (part that bolts to the top of the transmission and includes the bearing) and the tower itself. The bottom piece (I call that the "receiver") was not replaced.
'The Battle Wagon'
Transmission Adapter Options J.P. TDI Conversions 6 December 28th, 2018 17:07
Tdi transmission options. TokenRednek VW B5 Passat TDIs 15 September 3rd, 2013 17:09
Transmission Options - Need some thoughts mtcookson Upgrades (non TDI Engine related) 4 July 9th, 2013 21:35
3 Transmission Options for 2010 berks_tom TDI 101 7 January 10th, 2010 11:10
looking for some opinions on transmission options grimkiller TDI Power Enhancements 3 April 21st, 2008 06:30
Page generated in 0.16560 seconds with 13 queries
[Output: 133.34 Kb. compressed to 111.59 Kb. by saving 21.75 Kb. (16.31%)]
