kooyajerms
grocery getter
- Joined
- May 5, 2004
- Location
- Pomona, Southern California
- TDI
- 97 B4V (mine), 11 x5 35d (hers) 04 V10 (that one you want), 2014 Q7 (mom's) 74 Shasta 1400
This is the turn signal komfort mod, that allows the tap and 3 flashes from the indicators.
Someone said they have done the install. Well I looked behind the hazard flasher (relay location #6) and the wires don't match up the way the instructions state they do. Big thick live red wire sitting right behind, it doesn't seem to match up the same way... I'm really bad at wiring diagrams in bentley, can anyone help?
http://forums.tdiclub.com/showpost.php?p=1316678&postcount=54
I bought the kit http://www.worldimpex.com/item_detail.html?sku=278839TDIinRI said:pin 49a, white/green wire splices into T8d/1
pin 49R, green wire splices into T8d/2
pin 49L, white wire splices into T8d/3
pin 31,brown wire splices into T8d/6
pin 15, black/white wire splices into T8d/7
The pin numbers correspond the to Komfort Blinker relay that comes in the kit.....The coloured wires are already attached to the relay holder the comes with the kit. T8d is the connector that the hazard light switch plugs into. The number following T8d/, corresponds to which pin number on the T8d connector. The pin numbers are marked on the connector.
It took Lito and I about an hour to do. Not too bad, and a very useful feature
