Just turned 99398 miles on my 2011 Sportwagen and the Check Engine Light came on. This is the first time I've seen the CEL since I bought the car at 21k miles. The car had the fix done in September 2017.
A few days ago I had to run an errand of 4 miles one way and when i shut it off after the first 4 miles I heard the fans running, so it must have started the regen. I stopped for about 10 min and after coming home 4 miles again, I believe I heard the fans running again. Then I did a 30 min drive and shut it off. Then another 15 min drive, stop 15 min and 15 min drive back. No CEL at that time that I can recall. This morning I turned the key on a few times to pair a new phone to the car and when I started the car I noticed the CEL.
What do you guys think? Should I try a longer drive to see if it would do a regen successfully and turn the CEL off? I would hate to drive the 70 miles one way to the dealer only to find that the thing fixed itself by the time I got there. I attached some info below from VCDS related to the DPF.
Thanks.
Thanks.
Code:
Thursday,31,May,2018,13:20:49:58712
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
[url]www.Ross-Tech.com[/url]
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 B HW: 03L 906 019 DA
Component and/or Version: R4 2.0l TDI G000AG 9983
Software Coding: 0050078
Work Shop Code: WSC 09936 003 1048576
VCID: 2D7FD48EB4F4662CBC-8078
1 Fault Found:
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 159895 km
Time Indication: 0
Date: 2020.14.31
Time: 18:21:30
Freeze Frame:
RPM: 1771 /min
Speed: 89.0 km/h
(no units): 71.4
(no units): 40.8
(no units): 2.43
Pressure: 256 mbar
Pressure: 38 mbar
Readiness: 1 1 0 0 0
Address 01: Engine (03L 997 030 B)
13:29:14
0 mbar Particle Filter Offset Different. Pressure
144.0°C Temperature prior Particle Filter
138.0°C Temperature after Particle Filter
0.0 Successful Regenerations
3.0 Requested Regenerations
100 km Mileage Since last Regen
108.0 Time elapsed since Regeneration
90 ml Particle Filter Oil Ash Volume
10.8 Soot Load(g) Calculated
0.0 Soot Load(g) Measured
