Old August 5th, 2016, 10:00   #1
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Default ALH in a 2.5L MK5 Jetta
Legalities aside, is it possible? Biggest problem seems to be having the ECU communicate with the MK5 can-bus network. I haven't tried hooking up a MK4 ECU to the MK5 can-bus network but I am really wondering if it would communicate or not.
Regarding mechanical, MK5 has electric PS with its own controller so it looks like all it would need is a PS pump delete and a bigger alternator. The clutchless AC compressor should fit, and BRM boost piping should be a bolt on.
Thoughts?
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old August 5th, 2016, 18:17   #2
turbocharged798
So something interesting I found, the Bently manual for MK5 says that the stock auto 09G slushbox has very similar gearing to a stock ALH 5 speed in 6th gear. Since the 5 cyl uses the same bell housing as a 4 cylinder, the ALH should bolt right up. Problem is that will the TCU even communicate with the ALH ECU and rest of the car via can-bus. I have no idea.
Old August 9th, 2016, 08:27   #3
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
as far as i know, nobody has figured out how to make an ALH work with an 09A trans in regards to ditching the 01M for an 09A on a MK4 car.
Anythings possible with enough time and money but i think your looking at creating a completely standalone trans controller to make it work... and thats if the engine side works right to begin with.
Maybe look at some euro options? maybe something that came with a mk4 engine electronics, while using mk5 body/trans electronics already existed there?
electronics isnt my bag, just spitballin here...
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Does anyone know if an ALH can be swapped into an MK5 Jetta? stevesky TDI 101 28 February 12th, 2017 11:39
Iveco 2.5l mechanical to ALH? Halfbrit TDI Conversions 11 July 14th, 2016 06:12
FS: NH , (NEW) Monster Mats + CarGo Rear Liner - Sportwagen, Golf Mk6/Mk5, Jetta Mk5 twilsey Private TDI Items for Sale/Wanted 3 March 23rd, 2015 11:27
FS in CT, 5.5l, cup holder console, ALH EGR, IP lines acmercg Private TDI Items for Sale/Wanted 2 August 14th, 2014 09:42
:: ECS Tuning :: Schwaben Mk5 2.5L / TDI Brake Rotors - Blowout Pricing !!! ECS Tuning Vendor & GroupBuy items for sale 4 January 13th, 2011 02:02
Page generated in 0.12667 seconds with 11 queries
[Output: 60.35 Kb. compressed to 54.87 Kb. by saving 5.48 Kb. (9.08%)]
