- Joined
- Jul 2, 2000
- Location
- Springfield, VA
- TDI
- ‘18 Tesla Model 3D+, ‘14 Cadillac ELR, ‘13 Fiat 500e
Drywaller, you want to bench focus the lamp (adjust it up/down/side within the housing) so that half of the hot spot is below the cutoff line and half is above the cutoff line and the hot spot side-to-side lines up with the step in the cutoff line. Jason and I ended up having to shim one of the lamps a little bit with some aluminum foil because the hot spot's natural resting point was above the cutoff line, making the low beam very dim. We actually adjusted them so that about 2/3 of the hotspot is in the low beam and only 1/3 is in the highbeam, sacrificing some of the high beam illumination for extra low beam illumination.
As for the lamps, I'm considering purchasing some premium lamps to put in there to see what sort of difference that makes. The ones that we got from Jeff has some interesting color shift towards the outsides of the beams, with only the hotspot being 4300K.
