MAXecutive
Hi everyone! I wanted to create a DIY that covers a boost gauge installation on the 2.0 CR TDI engine. There are many threads asking about this topic but not much pictures to guide people through the process. I decided to install a boost gauge after having issues with a frozen intercooler. I know it wasn’t necessary but I figured it would be cool to have some type of indication of boost behavior during the cold weather.
I decided to go with the NewSouth Performance Boost Gauge since it has no vacuum range and provides more needle deflection on the stock boost range of 0-23psi. It also has a perfect match to the needles on the MK6 instrument cluster. I looked into other gauges such as Podi but did not like the asymmetric steering column gauge pod. AWE Tuning had the best mounting solution in my opinion, the vent gauge. This left me with a dilemia since NewSouth does not make a MK6 Jetta specific vent pod and AWE was not willing to sell the pod alone. I ended up purchasing the NewSouth Gauge AND an AWE GLI Boost/Vacuum Vent Gauge just for the pod. I still have the gauge for sale here:
http://forums.vwvortex.com/showthre...ost-Vacuum-Gauge-52mm&p=86629081#post86629081)
To use AWE’s pod, you need to remove the electronic gauge and cut the flat plastic bar off.
The NewSouth gauge fits into the standard opening but is very loose. I experimented with wrapping electrical tape around the gauge to build up the gap and make it fit tightly. I didn’t like how the result felt and the smell of heated paste from the electrical tape coming out of the vent wouldn’t be too pleasant. I decided to use pieces of the soft side of industrial strength Velcro to make a balanced cushion layer between the gauge and pod. This method works well and allows you to easily install and remove the gauge and rotate it in any position you prefer.
I used a combination of the instructions provided from NewSouth Performance and AWE Tuning to install the pod and run the boost line through the firewall. I will skip over those parts and the wiring of the NewSouth Performance gauge lighting.
I did everything above within weeks of buying the gauges then I found out how much of a pain it is to install a boost gauge on this engine. I was used to tapping into any vacuum line off the intake manifold from a gasoline engine. Several months went by of me starting at a boost gauge that only lit up and served no purpose before I decided to actually attempt to install the boost tap. I chose the plastic intercooler pipe as the easiest place to install the boost fitting. The process I used did not require taking the pipe off the car!
I did not have all the necessary Torx socket wrenches to completely remove the belly pan. As long as the car is up in the air a few inches, you can loosen the front and side screws and let it hang down. There are 4 screws on each side and 1 screw in front with 2 interlocking tabs.
The next thing I did was remove the rubber intercooler hose from the plastic pipe. My car had the updated intercooler installed in February 2014 so your hoses and clamps may look different. I only had about an ounce of clear water in the hose and barely any of that brown milky residue on the inner walls.
