scubagli
97 golf Tdi swap
I am considering moving on, turns out I do not really care for the mkiii chassis...
The motor and trans have 287k did t-belt @ 274k, at the time of the swap I did a 5 lug conversion.
RC3+ chipset running 18psi
Replaced
Tie rods
Ball joints
Control arm bushings TT rears poly fronts
Has bfi poly .5 motor mounts stock VR trans mount
Replaced rear beam bushings w/poly inserts
Rear wheel bearings
Stainless brake hoses at all corners
Has weitec coils
Power steering delete
drivers edition rear 60/40
At the moment it has a check engine for glowplugs ive replaced the harness, the glow plugs, checked all the fuses, i'm about the do the relay mod. It is registered as a diesel and inspected has ****ty rattle can paint job...
The shell has some rust underneath, it was previously repaired in a half assed manor...but over all not to bad...not a show worthy car but a good daily that returns 38-42 mpg in mixed driving.
I'm asking $2850.
Please do not hesitate to contact me, for more pictures or more info.
The ATS wheels are gone currently sits on 15" mkiv wheels with brand new snows.
Drtyeuro
Replaced
Tie rods
Ball joints
Rear wheel bearings
Has weitec coils
I'm asking $2850.
Drtyeuro
