sloguydoin75
I finally could not handle the rough stumbling that my retarded jetta was experiencing, It was getting bad. Clouds of white mist even as my wife was driving it.And it was still getting 42 mpg. I pulled the injectors and found them caked with soot. Cleaned them, even took them apart and spray/chem cleaned them to see what I need to do to change out the noozles. The "216 that is 203" appears to the best choice. (I'm open for your input.) I think I will swap them out when my wife is not looking. I wonder if she will notice? Any way, Then the car would not start. Well, I did not purge to fuel line to the injectors. Lucky for me I had made plans with Robby, Runonbeer to help me set the timing. We reinstalled the injectors and it still was a no go situation. Until I mentioned the purging issue. JOb done. The engine started. Now the Vag-com. I think I saw Runonbeer cry at the read out. Mirror in hand we checked the TB and tensor. More tears of terror. My poor Jetta had been molested by a dealership!!! when they did the TB. The tensor was not set to the mark. The Pump was way out / beyond retarded MORONIC best describes the statis. Finally after things were set, we went back to the pump to change out the stretch bolts. Each one was about 3/8" longer than new ones. Guess what I plan to do with the engine mount bolts that the stealership did not replace when they did the TB. Do you need another guess? yah replace those critters real soon before I loose the engine. My sweet wife would not like that. She has asked me several times "will this engine fall out?" I better get to that ASAP.
