clifford.hubbard
With AC on, air intake closed, neither fans are turning. Thoughts? Thanks
Cliff
Cliff
Yes, and the RCV is very common failure point. Mine was not working when I bought the car. I didn't know it until the weather warmed up. The 1st dealer (Modesto VW) claimed in was out of Freon, charged it and sent it out the door and tried to charge me claiming no CPO coverage. That day it happened to be cold so I couldn't really know. NO bueno. I went to a real dealership (Tracy VW), they did the repair right. 0 deductible!so there is no clutch on these cars . the compressor spins all the time . the system uses a refrigerant control valve on the compressor. you either have a defective RCV or a stuck exspansion valve or the charge is too low. int needs to be hooked to a reclaimer and verify the refrigerant charge first. then diagnose from there
That's interesting. Gotta wonder, with Freon low, what the logic is when the ECU lets the A/C run and turning off the fans.Also fans are spinning!
