Owen81
Hello,
I'm having a lot of trouble trying to bleed my clutch, first, some background:
One morning I noticed my clutch pedal felt odd and was engaging lower that usual. I kept driving it like that for a week or two with no noticeable change in the clutch behavior.
Last weekend I took a long trip out of town, everything seemed ok, but after parking for the night I noticed my clutch was engaging very low, and wasn't complete disengaging as it was very difficult to shift into first and second. The symptoms got better as the car warmed up.
Upon returning home, the clutch was engaging low but still working. However, the next morning I couldn't shift into first at all, the clutch wasn't completely disengaged.
I decided to try bleeding the clutch as it is the least expensive fix.
With the reservoir completely full, I opened the bleeder nipple, pushed the clutch down and had a lot of fluid exit the slave into the bleeder hose. The clutch stayed on the floor.
I closed the bleeder nipple, raised the clutch by hand then opened the nipple and pushed the clutch down again. This time I hardly got any fluid out. I did this for 15 minutes with no appreciable amount of fluid in the bleeder hose.
I found a helper and saw that the fluid would come out, but when I opened the bleeder after raising the clutch, the fluid would drain back into the slave cylinder.
I ended up getting a pressure bleeder, set it to 12 psi full of DOT 4 and opened the bleeder nipple. I had some fluid come out but it stopped after maybe 20ml was in the hose? I could have more fluid come out of the bleeder if I pushed the clutch pedal to the floor (where it would stay) but it would just drain back into the slave upon raising the clutch, even with the pressure on the fluid reservoir.
I tried all sorts of different things trying to get the fluid to bleed out, but only managed to get about 50-75ml out total.
One thing I noticed:
The only time I felt pressure when pushing the clutch in, was if I allowed all of the fluid in the bleeder hose to drain back into the slave cylinder. However, the fluid that would exit the slave was never more than what had drained back into it.
So, what would cause the fluid not to bleed from the slave cylinder with pressure on the reservoir?
Yet allow the fluid to flow when pushing the clutch pedal in?
Is it normal for the fluid to drain back into the slave cylinder?
Thanks for reading, please help!
