With the volume of the DEF tank and the Passat's miserly use of the substance, I think placing it in the trunk makes perfect sense.I actually don't care one bit for having the diesel fuel / AdBlue fillers together right there under the fuel cover. Yeah, they're easily distinguished, but I know that Murphy never sleeps, and I've seen stranger things happen than someone dump a bunch of AdBlue into the fuel tank. Or vice-versa.
It seems that the whining increases in the winter time once all of those electric heaters get fired up.Boy I sure do see a lot of whining on the forums about the Passat TDI... yet they DON'T whine and complain about the fuel economy data.... Some people need to swallow a pride pill and drink a quart of shut-up juice !!!
Agreed.With the volume of the DEF tank and the Passat's miserly use of the substance, I think placing it in the trunk makes perfect sense.
The Germans have been aware of climatic conditions in North America for some time, so we are able to simply drive in a normal manner and park outside whenever we wish.Guys, I've heard AdBlue is really sensetive to cold.
What do you do in freezing winters?
Let's be accurate here--DEF is not consumed in the engine, rather it is used in the exhaust system. It is metered out as needed at a rate that depends on driving conditions. The system does not need DEF continuously, which is why if DEF freezes the DEF tank heater can thaw it out by the time it is needed.AFAIK there is a tank heater that keeps it from freezing (or at least thaws it if it does) and provides DEF to the engine till it warms up.
Just to add another data point. I brought my car in for a check engine light issue. While there, with 8600 miles on the clock, the dealer suggested he could do the 10k mile service as well. So, service was performed and when they brought the car around front, I asked how much Adblue it took. The Tech replied they didn't but any in as there was no indication that it needed to be filled. I talked to the Service Manager, and he directed the shop to top off the tank. It took 3/5ths of a gal. in 8600 miles. I was surprised at the low usage of adblue. But they didn't spill any while filling, so I was happy. I spent some time talking the service manager, and he told me that VW stated specifically that the dealer was not to add Adblue unless the indicator light on the dash called for adding. Period. Now this is a new Dealership, with everyone coming from the world of Toyota and Lexus, so they have a lot of learning to do. But, I like them, they are courteous and anxious to satisfy and willing to do what it takes to keep a customer happy. He also said that they no longer could get the small bottles with the fill neck that work so great on these cars. They could only buy bulk Adblue, but had fashioned a few funnels out of some of the screw on bottles to prevent spillage.Just wanted to give a longer term update on my AdBlue range experiment. I do all my own service and last filled my urea tank at 10K miles. I just passed 28K on the odo, so I'm at 18K miles on my latest urea refill with no warnings yet. I'm hopeful to settle into a 20k cycle for urea fill and it looks like it may be very doable.
Interesting, bound to get a few upset customers especially since the 1st item on the maintenance schedule is.... I spent some time talking the service manager, and he told me that VW stated specifically that the dealer was not to add Adblue unless the indicator light on the dash called for adding. Period. ...
Thanks for this post. I have been searching for a while to see if it's really necessary to have the screw on bottle or not. I can understand how it prevents spills, but I'm happy to know that I don't need to use it. Any 'ole funnel and a slow controlled pour from a jug should fill the tank and not spill all over the place. It might require 2 sets of hands, but I think I can manage to get some help every 10-15k miles.OK...my turn. Im on a mad dash to Hays Kansas to watch my daughter play college softball and my DEF warning comes on. Says 1500 miles left. No big deal until 90 miles later it says, "900 miles left" . At this point Im 200 miles from the closest VW Dealer and not trusting my guage. I call my dealer and tell him im not sure they topped it off at the 10k and can I use walmart DEF. He says no, but he will let me talk to parts. The parts guy says " he cant tell me I can use Walmart DEF...but it is all the same stuff" I used a short transmission funnel with with a ridge down the outside for air so the tank can breath while you fill it. I did not know how big the tank was so I would add about 1/2 gallon at a time and check the fill neck to see if I could see fluid. Took all 2 1/2 gallons and could see fluid in the tank. Did not spill a drop, no drama, The filler tube that comes with the Walmart fluid makes it pretty easy. Could be done without the funnel if you had to.
Lessons Learned:
1. No special filler tubes are necessary, a funnel makes easier.
2. Wal mart DEF is fine
3. FOWLER VOLKSWAGEN IN NORMAN OKLAHOMA LET ME DOWN AGAIN....
If you are reading this, dont panic. Good luck!!
Jay
Don't believe the AdBlue levels in VCDS. There are a number of sensors in the AdBlue tank that report "level," but they can be misleading.My 2013 Passat TDI SE has just under 13.000 miles on the odometer. At around 8K, I bought a VAG-COM cable to perform a few tweaks. When I did, I happened to check the AdBlue percentage level and it was about 97%. At that time, i figured i needed to gain more knowledge with the software. Later, I noticed on the technician's report from my 10K service that very little DEF was added with the servicing. I just checked the level again (with VAG-COM) and it says 100.2%.
Obviously, the car is using very little (if any) DEF. should I be concerned? My overall mileage is about 40mpg in about 60-40 highway-city driving. On my last trip to No. VA taking my wife to Inova Mt. Vernon, I averaged 52mpg.
No you can just refill.
FYI, the last 10,000 miles on our car we used 3 gallons of AdBlue
-J
Doesn't the manual state that if you are going to add Adblue to the system that you need to add at least 1.5 gallons?To me, if the car is in for service for any reason, why not go ahead and top off the Adblue. It is arleady there, you check all the other fluids, why skip this one?
